10pcs USB LED Portable Night Light Bright Mini Keychain Camping Car Lamp Module
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
Never be without light or emergency lighting again. Purchased these initially for another use and found it will work on the phone.
10pcs USB LED Portable Night Light Bright Mini Key Chain Camping Car Lamp Module
https://www.ebay.com/itm/10pcs-USB-LED- ... SwoJhdyOfd
Only con is it's super bright so will be bothersome if pointed in your direction
1) Can be attached to key chain.
2) With a long cable can be used with USB in the car while working on the car.
3) Use phone or battery pack for working on the car
4) With a longer cable can reach hard to see places in the engine bay
5) Use as regular light while working on the car
6) With a short cable can fit in the jacket or shirt pocket walking in the dark
7) Use as utility light making repairs anywhere
8) For inside wall or plumbing
9) Endless uses
10) Turn old chargers into night lights anywhere with an outlet
MoVolvos
Post by MoVolvos »
Purchased a 15' extension cable for $6, attached the LED and zip-lock bagged it in the car. Should of gotten a 25'. Can be used all around the car if its dark out. Just inserted into the cigarette plug with one or two USB output. No need for the phone, flashlight or pulling a light from the garage. If you want more light get a splitter. It's actually brighter than in the picture as the garage is completely dark. Definitely enough light to work under the hood. Can also provide lighting while driving to anyone in the car.
https://www.ebay.com/itm/USB-2-0-A-Male ... 2749.l2649
https://www.amazon.com/INSTEN-USB-2-0-E ... 229&sr=8-4
