So with the background explained, here is my issue. I have DIY replaced all seven motor mounts, and the front control arms and balljoints. This has made a MASSIVE improvement in how the car drives. It had some fairly epic vibration and clunking and banging going on. Before doing the motor mounts, even in neutral it rattled the dash. Now it is just about perfectly smooth in neutral. But there is still what seems like substantial vibration and "boom" when idling in gear and stopped. It goes away as soon as I start moving a bit, but it's pretty annoying - especially with FL 5-minute traffic light cycles. Doing lots of reading, the subframe bushings COULD be an issue, but I don't seem to have any of the other symptoms of them being bad. From what I can see of them without taking the bolts and plates out they look "OK". They do seem VERY hard - I am sure the FL heat has baked them to a fine crisp.
So will replacing them make a big difference in this case? I haven't driven another one of these cars in many years, so I don't know what normal is for them. I have had a couple of Saab 9-5s that are notorious for this stopped in gear vibration, this car seems on par with them. But I don't recall that being a big complaint with P2 Volvos the way it is with the 4cyl Saabs. Replacing them doesn't look to be much fun, though not worse than what I have already done.
All thoughts appreciated!
Pretty car:
pax side by kevinr1916, on Flickr-Kevin
