TD04HL-19T Turbo Topic is solved
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 305 times
Been thanked: 517 times
TD04HL-19T Turbo
Post by bmdubya1198 »
Good used 19t turbo. This was run on a friend's car for about 5k miles before it was wrecked. The wastegate actuator has been set to 5.6 PSI per specs for the 2000 V70R on which this is installed from the factory, however the pin for the actuator rod is missing. No big deal, I usually use a paper clip or small cotter pin for these. It's nothing special.
This has the 7cm3 exhaust housing as well, with no cracks that I can find. This is as good as you can get for a bolt-on factory turbo for P80 and P2 cars, and you could upgrade to a billet wheel for even more bang for your buck.
$275 plus shipping.
gbc02
Year and Model: 1997 850 awd
Post by gbc02 »
Is this still available?
Does it have the early or later coolant ports?
Thanks.
bmdubya1198
It has been sold, sorry!
