1994 volvo 850 turbo vacuum routing Topic is solved
JoeHester
Year and Model: 1994 Volvo 850 turbo
Post by JoeHester »
Almost finished refurbishing my 94 turbo (pcv, turbo vacuum lines, etc) and I either made a mistake somewhere or am just not understanding the next step. So from what I can gather from other forums about the vacuum hose in question (top rear nipple of vacuum tree>metal loop under spark plugs cover) is supposed to go to the ptc valve. However, the ptc valve is already occupied by the two hoses in the rubber sleeve that goes under the manifold. Any ideas on what I'm missing here? Thank you and sorry for the wall of text :roll:
Has thanked: 1610 times
Been thanked: 4065 times
The PTC isn’t a valve , it’s just an orfice. It attaches to a fat hose that runs to the canister hanging below cylinder 1 and 2
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Your 94 will have a few other vacuum lines that this 98 doesn't have, but this thread should solve most of your questions: viewtopic.php?t=63615
Also your car has w white sticker under the hood showing all the vacuum lines.
JoeHester
Post by JoeHester »
Okay I think I got it figured out now I bypassed the metal loop under the spark plugs cover by routing my vacuum tree to my ptc and fuel pressure regulator
s70t5ing
Year and Model: S60 T5 M66
Post by s70t5ing »
Bumping this as I am doing the breather on my 94, and it has a few different connections VS. my 97 turbo. Can anyone let me know where the second line that goes to the top of the ptc goes? Thanks.
1995 850 Turbo, 2005 S60 T5 M66, 2009 S60 2.5T AWD
