Bookmarking this one again as it’s awesome, and will be needed soon here in the North East!
https://images.matthewsvolvosite.com/vo ... torial.pdf
SUMMER 2021 is NIGH!!! Ac repair tutorial 2017 by JimBee, DIY
- Has thanked: 2857 times
- Been thanked: 1332 times
Excellent tutorial, just great.
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
That version is 21 meg because the pictures are uncompressed. I've attached a version with compressed images that's under 1 meg which I had downloaded in 8/2018. Looks identical.
I have also attached:
The AC clutch fix PDF by Nathan Bryant
The AC refrigerant recharge thread by pfeener (which I thought was worth making into a PDF)
I also have the "AC evaporator replacement book" PDF written by CLC, both a 2008 and 2017 version. It clearly says "not to be re-hosted... without the consent of the author" at the bottom of each page so I won't upload it here. I would post the author's email address (also at the bottom of each page) but I'd hate for them to get spam. Did I get it from this thread?
Here are some other links from my notes. I haven't checked these in years:
"Step one: what is the refrigerant pressure in the system? Step two, what is the clutch gap?"
Video re: cycling, etc
Video re: clutch gap
Pic of temp cut off switch on compressor which can be jumped
The compressor bread clip fix
Measuring the clutch gap on a 2000 S/V70
"Never replace an a/c clutch only, the compressor will fail shortly after."
850 condenser and evaporator replacement
List of info links for condenser/evaporator work.
Good 2019 A/C thread
Can you tell that my A/C is dead and I've been preparing to fix it? I did this research and bought the parts for my old blue V70 but it got totaled before I did the work. Good thing I got a green V70 with the same problem.
AC repair for 850 - JimBee.pdf- (994.17 KiB) Downloaded 122 times
AC cluch fix.pdf- (544.82 KiB) Downloaded 123 times
AC refrigerant recharge.pdf- (69.97 KiB) Downloaded 134 times
FireFox31
.... and green is cooler on the electromagnetic spectrum, too
Thanks FF31! I swapped yours in place of the 20+MB version. https://images.matthewsvolvosite.com/vo ... torial.pdfFireFox31 wrote: 06 Apr 2021, 15:48 That version is 21 meg because the pictures are uncompressed. I've attached a version with compressed images that's under 1 meg which I had downloaded in 8/2018. Looks identical.
There's some server-side caching happening, so I don't know when it'll make the new version available at that URL. So although the switch is global and permanent, it'll serve up the large one for some time.
Crap. I missed that. We used to ding our students for not scaling their pictures to fit the resolution of their microscopes.
Hmmm. That file is twice the size of my very first hard drive installed in an IBM XT PC. That screaming 8086 chip and it’s 16 bits
- 7600 Views
Last post by erikv11
- 2318 Views
Last post by C1ph3r
- 594 Views
Last post by ranson-volvo
- 14 Replies
- 4675 Views
Last post by darylrobert
- 40 Replies
- 11733 Views
Last post by vtl
