302 rotors fit under 16" Perfos?
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
I believe so. I suppose I could ask if a 302 upgrade is even worth it, though territory here is treacherous I know. Would be for 855 wagon, basically normal enough driving habits don't drive it hard. Thanks!
rguzz
Actually did a quick search through MVS and realized I've asked a similar question before and consensus seems to be the Perfos will fit. I'm doing front brakes anyway which makes the "upgrade" tempting and probably wouldn't do it otherwise. So, maybe worth it?
- Has thanked: 2857 times
- Been thanked: 1332 times
Hey why not? You wouldn't be asking if you didn't want to do it, so do it. You live once...
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
Yes, Perfos fit the 302's, and it's a worthwhile upgrade over the marginal stock 280's.
Do it.
Do it.
- Has thanked: 2200 times
The upgrade is worthwhile, and relatively easy. I would suggest replacing the flexi-brake lines. If I recall the 302's need a longer line over the 280's, but I may be wrong.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
The 302s should be used with longer brake hoses, but they work perfectly fine with the stock hoses. Been running them for a few years now this way. If flexi brake lines were legal over here, I'd surely run them, though.
Columbas, even if they look similar to Perfos, are the 16 inch wheels that definitely don't fit unless you want to modify the rims or brake calipers in a scary way.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Been thanked: 4067 times
Columbos?
“ there’s just one more question, Sir....”
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 114 times
Can confirm that Columbas do not fit
I got new hoses when I went 302, might as well replace the 23yo original ones
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
- 1284 Views
Last post by Clemens
- 1076 Views
Last post by benpineapple
- 1233 Views
Last post by bmdubya1198
- 348 Views
Last post by Ragman
- 2195 Views
Last post by Reys
