'98 C70 coupe
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
dlehnhoff
'98 C70 coupe
Post by dlehnhoff »
1998 C70 coupe. Which line do I tap into to install a boost guage. MY gauge has the lower part as a vacumn and the upper as boost. I am assuming that most lines have negative pressure, so which would produce boost pressure??
Thanks
Dwight
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Dwight,
I just tapped directly into one of the spare ports on the vacuum tree. Uncap one of them and hook up directly to it. It works well, then you don't have to use a T-tap.
MIJ
