Just wondering what the agreed method to alternator troubleshooting is. While driving yesterday the battery light went on, with a "EL.POWERSYSTEM SERVICE REQUIRED" message on the info center display. When I got to my destination I left the car running and slapped the multimeter on the battery and got a read of 11.6V ! (Very low brownout) Car off- 12.6V (actually an OK reading for an idle battery). My first thought is the alternator itself, and likely going for a rebuild to make sure I have a new pulley/fresh bearings from a reputable local rebuilder. I plan on taking the alternator off and using this thread viewtopic.php?f=9&t=51058 to troubleshoot and see if the regulator is the issue as well... but I think while I'm in there I really should just replace the whole alternator anyway in order to ensure I have new mechanical parts. Battery is only about a year old Kirkland H7 so I really don't think it's that although I will get it load tested while my alternator is on the bench getting tested as well.
Am I on the right path or not? This is part of an ongoing rough patch I've been having with the 04 xc70 in the past month (First exhaust leak, discovered that I needed ball joints, after replacing ball joints ABS light comes on and I had to replace my rear wheel bearing this weekend... now alternator?
