96 850 turbo- no start...no spark...no cel
mrbrightside2009
- Year and Model: 96 850 turbo
- Has thanked: 1 time
just had the engine swapped out, car cranks but won't start...not getting any spark...also no check engine light showing on dash with key in the on position. tried plugging in scanner...says communication error with ecu. swapped out coil.....crank sensor... plugs ..wires.. cap rotor...coil all brand new. also checked all fuses... one of the immobilizer fuses were blown...replaced still nothing.
- Has thanked: 294 times
- Been thanked: 767 times
Check cam sensor, also how about are the little plates on the back of the cams in the correct orientation? I'd check them both.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- misha
- Has thanked: 152 times
- Been thanked: 403 times
This means that ECU doesn't get power.mrbrightside2009 wrote: ↑10 May 2021, 19:08 ...also no check engine light showing on dash with key in the on position...
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
mrbrightside2009
ok still messing with this.... found a few grounds not hooked up....one by starter, small black wire and one on firewall....coil seems to get really hot after cranking... 2 plugs are unhooked....the black one is under the manifold but doesn't seem to have anywhere to plug in....brown is by the passenger headlight.....what are these for?
- Sveedy
- Has thanked: 418 times
- Been thanked: 457 times
I have the same car - I can't see where that black plug you're showing is. Maybe a little better picture and I could tell.
The brown/orange plug should just be clipped to the back of the headlight assembly. There is one on each headlight housing.
I'm guessing for fog lights but that's just a guess.
1999 V70 GLT
1999 V70 GLT
Is the cam sensor connected? Is the crank sensor connected? IAC and TPS also in that area but I did not go and look what color their plugs are.
Also maybe let us know many pins on that black plug (tewo?), might help to figure out what it goes to.
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
Azik09
- Year and Model: S70 T5, 1997
- Has thanked: 2 times
- Been thanked: 31 times
Brown connector is for headlight adjustment. Black connector seems like knock sensor, it does not affect spark and injection. As misha said above, ECU is not powered, it's 100%. You said about disconnected ground wire near starter, there should be 1 or 2 more. Maybe they are disconnected too?
If my English is bad, please correct me
Almost but not quite 100% just because bulb could be burnt out for the CEL ...
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 96 times
- Been thanked: 337 times
Is the ECU ground under the PS headlight in place?
mrbrightside2009
not seeing a ground under the headlight....took it out...not even sure where it would go...can somebody get a pic please?
check engine light was lit 2 months ago...doubt it burned out.
- 2514 Views
Last post by Roger_850T
- 2883 Views
Last post by ndphotonl
