So I was getting a timing belt replacement done and it got out of time it seems. They did not mark the timing before hand and I think it fell out of time because one of my cam shaft pulleys spins a little bit (i think because it is a CVVT) and we don't know where it was originally. We've been trying to get it back in time and need help.
We can see the "M" markers and get them to line up but that doesn't seem correct and we see two of the "I" notches, but they won't line up at the 12 position
Will the "M"s work as an indicator or do I need to use the notches?
I can see the notches on the crankshaft pulley, how can I be certain it is lined up? It looks lined up from my point of view but I don't know if it's on the money.
Timing help needed
blaconator
- Year and Model: 2004 s60
- Has thanked: 6 times
- jonesg
- Year and Model: 2004 V70
- Has thanked: 69 times
- Been thanked: 479 times
"M" and "I" notches ?
what is the 12 position.?
Last time I changed the belt I locked the cam sprockets, released the tensioner, slipped the old belt off and slipped new one in place, done.
You don't need to do everything in this video if you aren't changing the cam oil seals.
blaconator
Thank you for the response and help!!jonesg wrote: ↑12 Jun 2021, 04:17 "M" and "I" notches ?
The "I" notches and 12 0 clock position refer to the markings shown in this image
- download.jpg (8.51 KiB) Viewed 905 times
- Has thanked: 927 times
- Been thanked: 999 times
Why are you lead to think it is out of time? If you use the I marks, you should get the correct timing as shown in the figures.
blaconator
I think it's out of time because it's not turning over when I try to start it and the only thing they messed with was the timing belt.volvolugnut wrote: ↑12 Jun 2021, 14:18 Why are you lead to think it is out of time? If you use the I marks, you should get the correct timing as shown in the figures.
Questions: Is 'they' a shop or just someone who helped change the belt? Does the engine crank smoothly without noise or stall? Does it try to fire and will not run? Are the I timing marks now in correct positions? If not, how far off are they? Beware! If the timing is much off, you can bend valve and damage pistons if you crank. If they made any electrical disconnects, that may be your problem with not starting.
blaconator
"they" is someone who helped me do the belt who used to be a mechanic. As far as I can tell, yes it cranks smoothly. Yes it tries to fire but can not run. They seem lined up but I feel I can get them on the money.volvolugnut wrote: ↑12 Jun 2021, 19:14 Questions: Is 'they' a shop or just someone who helped change the belt? Does the engine crank smoothly without noise or stall? Does it try to fire and will not run? Are the I timing marks now in correct positions? If not, how far off are they? Beware! If the timing is much off, you can bend valve and damage pistons if you crank. If they made any electrical disconnects, that may be your problem with not starting.
They disconnected the coolant sensor and alternator I can double check to make sure they are connected.
- Has thanked: 292 times
- Been thanked: 765 times
Just to clarify: rotating twice around is not some kind of fix, it is done to make sure that every thing is working properly. If you can go twice around by hand and the timing marks end up exactly as when you started, it should be good to go. You always want to perform this check when timing one of these interference engines.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
