2001 V70XC - does VIDA diagnose AC issues...
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 113 times
- Been thanked: 115 times
The warmer days are here. Would VIDA/DiCE report problem if AC set for cooling but blows warm air through the vent?
- kcodyjr
- Has thanked: 17 times
- Been thanked: 23 times
VIDA might or might not have something to say, depending what the problem is, but it does have a calibration procedure and it sounds like that would be a good place to start.
5 others that came and went
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 126 times
- Been thanked: 116 times
The only thing you can really do on VIDA with HVAC troubleshooting is the motorized dampers calibration. It doesn't really display AC pressures or anything. Standard troubleshooting here, make sure your compressor is running, might have to shim it, and check your operating pressure (likely a R134a leak). Use UV Dye or a sniffer to find your leak.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- 2455 Views
Last post by erikv11
- 1838 Views
Last post by RickHaleParker
