98 v70 2.4 vacuum hg off intake manifold
frisky99
- Year and Model: 1998 v70
- Has thanked: 6 times
Hello, trying to diagnose hard brake pedal using a mityvac . I get 20hg holding going to the check valve and 20 hg off the intake manifold. Is 20hg enough vacuum to open the check valve? Thank you, Bruce
- Has thanked: 2200 times
If your peddle is hard, and engine is running, then chances are that the one way valve has failed. It is a plastic part on the end of the vacuum hose at the booster. They do fail but not often. If you have a junkyard around you might be able to pull one from there.
- Has thanked: 316 times
- Been thanked: 531 times
20 in-hg is normal vacuum for these engines, so that should open the check valve. You probably have a bad check valve.
- 1552 Views
Last post by erikv11
- 756 Views
Last post by JimBee
- 721 Views
- 1164 Views
Last post by precopster
- 1307 Views
Last post by 98v70xc206
