850 rack job parts list
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
The TRW rebuilt racks are back at FCP and they're on sale, so I've been making up a parts list for the job. Obviously the rack and the high and low pressure lines, of course, plus outer tie rod ends. Also subframe bushings. Anything else?
- Has thanked: 1859 times
- Been thanked: 1719 times
Check your swaybar bushings and links for wear as you will be removing those while in there. Also check your rear engine mounts for condition as you will be in there with more access.
Worth checking any water hoses at the back of the engine and to the heater core as you will have more room there too. Not saying you have to change any of these things but worth checking before ordering.
