P80 (late 1999 2000 only) dash swap DIM ?
Has thanked: 1610 times
Been thanked: 4065 times
Contemplating a temporary swap of dashes so I can keep my 1999 on the road while I rebuild my dash mounts
Do I need to swap the DIMs for either
Immobiliser operation?
Maintain correct odometer?
Other reason?
Has thanked: 2199 times
Been thanked: 1852 times
Can't think why you can't swap it over. You can use your original speedo unit, and other than the airbag I can't think of anything other than wiring that is left. Immobiliser is on the side of the LH A pillar.
I had a spare dash for a long time and then realised it was a 98 which is different. It can still be used but you have to change the wiring harnesses over. 99-00 are the same.
