New To Volvo's and looking to fix my hood latches
jboncher01
Year and Model: 1997 850 GLT
Has thanked: 3 times
Post by jboncher01 »
Picked up a 97 850 GLT and the hood only closes with the safety latches. It won't actually close all the way and was wondering if anyone had any clue how to get it to cooperate.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Welcome jboncher - So is the inside release handle, the cables and latches all there ? If so what happens when you pull the lever ?
If it all seems to be working, then does it feel like the latches just don't engage when you push on the hood to close it ?
1999 V70 GLT
Sveedy
Post by Sveedy »
It looks like there is a bolt that you can loosen and then adjust the latches up or down. Seems kind of weird that both latches are not engaging at all.
1999 V70 GLT
jboncher01
All the stuff under the dash is there. I need to check it out more thoroughly though. And yes pushing down on the hood doesn't make it latch. I think the release inside might not be retracting.
Has thanked: 2207 times
Been thanked: 1852 times
Be careful when adjusting the latches. Get it wrong and you have a stuck hood you will have difficulty opening.
There are adjustments on the latched to allow you to move the height of the latch up and down.
I would recommend removing the headlights and sidelights to allow access to manually release the latches if you over adjust them and the won't release.
Headlights are easy to remove although on the 850 you have to remove the plastic trim under them first which is a challenge to not break them.
As Sveedy mentioned, check everything works first. Lube the latches and then you can press the latches down without closing the hood and see if pulling the release leaver allows them to pop loose before trying to latch the hood down or adjust.
Good Luck!
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
Neil just said what I would do; with the hood safely in the air, use a small screwdriver or some such to push the latches into the closed position, then try the cable release inside.
I agree with sveedy, it's odd neither latch is engaging.
Have a helper pull the handle while you watch the drivers side to see what, if anything, moves. That cable is well known for stretching through old age. It is adjustable at the handle but if all else fails it's still available from Mother Volvo.
And welcome to our little Tribe.
Clemens
Has thanked: 500 times
Been thanked: 228 times
Post by Clemens »
Here is a link on how to make an emergency release. Do this first, it should come in handy if you end up with the possible stuck hood situation during adjustment mentioned earlier.
viewtopic.php?f=1&t=92045&p=572497#p572497
1996 855 R,
2010 V70 D5,
