Over Heating
Tedison
Year and Model: 2010 V70 2.4D
Has thanked: 2 times
Post by Tedison »
Hi I own a 2010 V70 showing 210k. I have posted before regarding running hot, but decided it would be better to do a clean update in the hope that someone can suggest anything that I've overlooked. I will start by listing the work carried out so far:-
1) Check for combustion gasses in the cooling system carried out. Negative.
2) New Volvo Thermostat fitted.
3) New Volvo temp sensor fitted.
4) Cooling system was cleaned and flushed.
5) New water pump fitted.
Symptoms
If the car is driven at 55-60mph with the A/C switched off the live data shows 105-112 deg C. The car has been driven for 50+ miles like this. Drive faster or switch A/C on, and the temp increases until ‘Engine running hot, Slow down.’ Warning lights up. As the temp increases past 94 deg the cooling fan comes on and increases in speed from 12%-94%. This has been checked and verified. The system does not lose water. The car has been driven approx 1200 miles since the fault appeared. The car heater works. The top hose gets very hot, the bottom hose, luke warm. Engine cooling fan runs at 93% and sounds like a jet engine.
6) New radiator fitted. Back flush (YESTERDAY)
After the new radiator fitted the temp was monitored at 102deg whilst stationary, the garage spent an hour trying to bleed any air from the system. They feel there is possibly still air in the system.
I took the car and drove 10 miles home (55-60mph) monitoring temperature. It rose to 107deg C but cooling fan on live data remained at 0% . 2 miles from home I stopped and switched off the engine for 5 minutes. On restarting the temp was 97 deg then almost immediately dropped to 88deg and the fan showed running at 12%. 100m from home the engine temp started rising again. I have removed the cap from the expansion tank and left over night. I should have scrapped the vehicle when this started but made the mistake of spending money on it.
Today drove the car, thought the problem was solved, after 10 miles temp stable at 89deg 12% cooling fan. Then engine temp cuts loose, climbs to 112deg with 0% cooling fan. Bottom radiator hose is stone cold. Please any thoughts…..
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Does the coolant tank cap hold pressure? The tank must pressurize to properly cool.
Can you check top and bottom radiator hoses with contact or non-contact thermometer after a moderate drive?
Can you burp the coolant tank by squeezing the top hose many times?
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Tedison wrote: 16 Oct 2021, 03:29 Bottom radiator hose is stone cold. Please any thoughts…..
Hot engine, cold hose. When you had the Radiator out did you check for a clogged hose? The bottom hose ( lowest point ) is where any heavy gunk will settle. Clearly there is no circulation through the hose otherwise it would heat up.
Active
Past
motormikeyman
Year and Model: 2004 XC70 AWD
Been thanked: 8 times
Post by motormikeyman »
It's possible the lower radiator hose is sucking shut but there is probably an air pocket in there somewhere.
'94 940 wagon, 220K miles- sold to a guy who then drove it to Oklahoma
'99 XC70 AWD, 210K miles- trans went
'04 XC70 AWD, 196K miles- still going strong
'06 S40 sedan, 150K miles- went with the ex
