Hi friends,
Just got back from a trip away and my wife drives the S70 as her daily. She said yesterday when she was going up an on-ramp' the electrical systems in the car slowly died out. She stopped the car restarted it and it went fine for the rest of the drive home. I'll have to scan it when shes home but i wanted to see if anyone has some easy answers for what could've caused this?
The battery is about 2 years old but a cheapish AutoZone battery iirc. The current alternator is a tested junkyard unit that i put in about 2 years ago also. The car hasn't given me any electrical issues in the 2 years I've owned it.
My obvious answers would be the battery, the alternator or a bad ground. The fact that she cut the engine and restarted it makes me think the battery is fine or at least had enough juice to activate the starter. Also, about 2 years ago the AC compressor seized so i drove it home with a smaller serp belt that ran the alternator clutch backwards (99's have a 1 way alternator so essentially it was just driven off the battery power) so that would make me think the alternator wouldn't have such a sudden impact... So this makes me worried that something like this could be caused by the ECM?
Any tips of where to start?
Thank you!
Sean
'Car electronics slowly died up on-ramp' - theories?
- smacknab
- Has thanked: 97 times
- Been thanked: 43 times
07 V50 T5 AWD M66 ~146k miles
- Has thanked: 928 times
- Been thanked: 1002 times
If the On ramp was a slope up with acceleration, perhaps a wire leaned back and shorted the electronics?
Returning to level, the short opened and everything was fine again.
Test with heavy acceleration up hill. At least that will be fun.
- Has thanked: 1853 times
- Been thanked: 1714 times
Is the battery hold down in place? Make sure it is so the battery is not moving.
Don't think it is the ECM. You usually get warning of this with random engine issues like limp mode.
Your wife is not one of those folks who likes to have a whole bunch of keys or other stuff hanging from the key ring? I am thinking this is more likely an ignition key issue.
- Has thanked: 1507 times
- Been thanked: 3823 times
You probably aren’t getting a good description of what happened. Definitely start with evaluation of the battery rest voltage, cables, alternator.
Also inspect fir rodent damage
- smacknab
Yeah this is actually correct. I talked to her more about it and she said the lights and the radio were fine the engine just slowly died. Maybe the throttle body or acceleration pedal sensor
How about something simpler like fuel pump relay. How full is the fuel tank? Maybe the tank is low or the pump is losing suction pressure?
Sounds a bit like limp mode on a 99 but that usually triggers the ETS light
Like abscate says, that is why I don't think it is the ETS/ETM. Anything is possible but not convinced this is the culprit, yet!
- 1015 Views
Last post by lummert
- 699 Views
Last post by TwoVolvoGuy
