My 740GLE will shift into overdrive unexpectedly, as though I pressed the switch on the shift lever. The dashboard indicator light will light up.
Happens almost every time I use the car, and has already cost me a headgasket. Any advice?
89 740GLE overdrive problem
Transmission Fluid and Volvo S40/V50, C30 & C70
jlex
My '88 704 was doing the same thing... OD light would come on unexpectedly while driving... it's the relay in the panel above the ash tray.... replace it & your problem will be solved.
jlex.
jlex.
It is also common for the wiring to wear through or break under the floor mats where they are constantly flexed from shifting, take a close look at the wires for damage.
