seat bolt is halfway stuck
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
So while fixing the heater mat for my 3rd row bench ...
Okay, in reality, it was the driver's seat. I need a warm butt in winter. Thought it would be easier to remove the seat from the car. Luckily i got 3 bolts out and the fourth bolt halway. I fixed the seat and most everything is good except that the rear bolt towards the center console is loose now because the nut that is welded to the chassis broke off.
I know someone had a similar problem here a while ago (maybe Neil?), but I can't find the thread.
I guess the only solution would be to cut a hole in order to access the hidden nut.
In that case I might as well live with just 3 out of four bolted down bolts...
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Has thanked: 1497 times
Been thanked: 3810 times
I would cut the head off and pull the piece out. Through bolt it with a new M10
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 999 times
Post by volvolugnut »
Perhaps you could use a captive nut like this. Cut the floor just large enough to get the captive nut slipped into the opening with the thread at the proper location.
captive nut.png (26.56 KiB) Viewed 306 times
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
abscate wrote: 11 Jan 2022, 16:23 I would cut the head off and pull the piece out. Through bolt it with a new M10
THIS! There are four solid mounting points
there to help keep you safe. Stay Safe. 8)
