found this bad boy sitting in pick n pull, wondering if the turbo would fit in my base model wagon, and what i would need to remove to complete the full turbo setup for some cheap power or if i should just take the whole engine since mine has an unknown amount of kms well over 500,000.
https://www.picknpull.com/check-invento ... 23V3391639
ideas, just not good ones
SirBrickWagon
- Year and Model: 1997 Volvo 850
- Has thanked: 7 times
- Been thanked: 11 times
1997 Volvo 850 Wagon (Non-Turbo) with too many problems to count
- Has thanked: 2199 times
I saw that one too. At least you may get an idea of the mileage on the engine assuming the milometer was still running before being scrapped. Problem with PnP engines is you have no idea if they are there because the engine went bad. Better to get the engine from one you can hear running.
If you have time and money on your hands go for it but you have only a 30 day return for in store credit.
Again, swapping the turbo onto yours is not normally recommended as NA engines usually run higher compression. I'll leave that for those who may have tried this in the past.
Good Luck!
Good Luck!
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
I remember reading that "swapping a turbo on to a NA is not a job for mere mortals."
What you should do is take those sweet Columba wheels. Maybe it's the filth on the car or maybe they're the rare anthracite grey ones. What do junkyards do with the wheels they take off the cars?
FireFox31
- Has thanked: 987 times
- Been thanked: 1075 times
Yards seem to like the fast, easy money of selling wheels for aluminum scrap. No worries about damage and no waiting for a buyer.
SirBrickWagon
judging by the rest of the car i can only assume they're dirty, i already have a set of those from bucks that i got with summers for 196 for a set, pick n pull says they don't take the wheels off the cars but i never see them on the cars once they've been all set up. just looking for some cheap power and something to do after school. might go look at a v70 i saw at bucks and try to sneak the turbo parts out (if it's turbo, there's not much details on bucks)FireFox31 wrote: 20 Jan 2022, 11:12 I remember reading that "swapping a turbo on to a NA is not a job for mere mortals."
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
Forget putting a turbo on your na. It’s a project for someone that can really swing a spanner. Easier and probably much cheaper to buy a turbo car and take it from there. Just my 2c.
BMW 540i 2002
S70 Base 2000
- Has thanked: 311 times
- Been thanked: 817 times
The engine and turbo are useless to your NA car.
- RickHaleParker
- Been thanked: 977 times
Stick a turbo on a NA ... are you in a hurry to get to the Kingdom of Heaven, Satan's domain or the Poor house?SirBrickWagon wrote: 20 Jan 2022, 10:11 found this bad boy sitting in pick n pull, wondering if the turbo would fit in my base model wagon, and what i would need to remove to complete the full turbo setup for some cheap power or if i should just take the whole engine since mine has an unknown amount of kms well over 500,000.
Keep your eyes peeled for Volvo 960s and 1997 - 1998 S90s & V90s. You can do the 960 TB mod on your 850 for some extra kick.
Active
Past
Past
This mod was so common back in the day, good to see it written up somewhere.
Link fixed: https://nordcarolina.com/blog/2018/3/18 ... grade-pt-1
SirBrickWagon
how ironic.. just found this in the same yard as the 850!RickHaleParker wrote: 20 Jan 2022, 14:46Stick a turbo on a NA ... are you in a hurry to get to the Kingdom of Heaven, Satan's domain or the Poor house?SirBrickWagon wrote: 20 Jan 2022, 10:11 found this bad boy sitting in pick n pull, wondering if the turbo would fit in my base model wagon, and what i would need to remove to complete the full turbo setup for some cheap power or if i should just take the whole engine since mine has an unknown amount of kms well over 500,000.
https://www.picknpull.com/check-invento ... 17S1064454
- 4728 Views
Last post by chumpden
- 669 Views
Last post by JetFixxxer
- 9746 Views
Last post by RickHaleParker
- 3181 Views
Last post by Bigbill55
- 40 Replies
- 4957 Views
Last post by 98v70dad
