hey everyone
Its -25C here and my 89 740T has no fan! I checked the 30amp fuse and it was blown, then replaced it, but it keeps blowing. Any ideas? im without a car until it gets fixed. thanks in advance
Its COLD help me out!! Topic is solved
LaRy
I would disconnect the fan motor. The fan is very easy to find and change in Volvo 740. Just take away the cover under the glove compartment at passenger's seat. You will see the fan(-motor), release one or two looking screews. Twist the fan maybe 180 degrees, and it will be loose. You will have it out within 15 minutes! Disconnect the electric connection and check if you still are blowing fuses. If not, get a new fan!
Guest
thanks so much
I got the fan to work, but now it makes this high pitch grinding sound? oh man it makes you want to pull your hair out! any thoughts on that? Ill try taking it out tonight.
LaRy
You said it was very cold. if the black rubber drain tube is not working, you can get water staying around the fan. Maybe the fan was stocked by frosen water when you blowed your fuses. Now the ice is gone and the fan is working. You need new grease for the bearings. Check the drain tube.
