1990 volvo 740 Topic is solved
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
wayne c
1990 volvo 740
Post by wayne c »
My volvo just dies , at any speed revs temp. There is no warning , no sputtering it just dies. sometimes i can put it in neutral and recrank the engine, sometimes it will not start for 20 mins. Have changed the fuel filter. I heave read of similar problems where filters, pumps (2) have ben changed to no avail . ANY ideas please.?
This started one day and has been driving me nuts
LaRy
Post by LaRy »
It could be the Hall sensor in the distributer or the ignition power stage, I have had both faults, and the car was acting like yours.
Look at the rpm-meter when trying to start, if it is showing 500 - 600 rpm, the ignition system is OK. If the rpm-meter is showing 0 rpm, ignition is dead and it could be a good idea to change the Hall sensor. It is always good to have a look at the rpm-meter when it's not starting, the rpm-meter is connected straigt to the ignition coil, low voltage side.
When my Hall sensor was broken, I found something very odd. I loosened the electric plug from the ignition power stage (with ignition off) and put the plug back again. The car started after that and worked sometimes for several days.
Lars
