Failure to pass California smog
stephenschachter
- Year and Model: 1986 244 wagon
My 1986 Volvo 244 wagon has failed to pass CA smog. It appears that large amounts or fuel is being pumped into the engine causing rich running (runs fine by the way.) It is expensive to have the smog test repeated, so I'd like to replace the likely suspect parts before going for another test. So far the fuel pressure regulator, spark plugs, cat convertor have been replaced. I intend the replace the 2 temperature sensors next. At that point I might try the test again. If it still fails, I'd think about replacing the air mass meter and the computer. Does anyone have any suggestions for an alternative approach? Any ideas appreciated.
- Has thanked: 2658 times
- Been thanked: 1248 times
I'm not good with the pre-90s Volvos, but can you post the failure test text? How is MPG? Any tailpipe smoke during acceleration or startup?
I'd add some fuel treatment in your to-do list. Also a good "Italian Tuneup".
Ensure the car is warm when you take it in for the test. 20-30 minutes of driving warm.
- Has thanked: 928 times
- Been thanked: 1002 times
If your car still has the flexible hot air tube and thermostat valve in the air intake box, remove them. The air thermostat often malfunctioned and forced hot air into the engine all the time.
- Has thanked: 1507 times
- Been thanked: 3823 times
Post up a copy of your smog report.
The data there will guide to you what’s wrong
- BlackBart
- Has thanked: 927 times
- Been thanked: 885 times
Those are expensive steps without knowing the cause. The steps mentioned above by others are next.stephenschachter wrote: ↑13 Apr 2022, 14:45If it still fails, I'd think about replacing the air mass meter and the computer.
O2 sensor(s).....??
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 131 times
Get a scanner on it, and look at live data..... o2 sensors and fuel trims, for example.
EDIT: It'll have to be a scanner that will do OBD1. I'm not sure if modern scanners will do that anymore.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
OBD arrived later, and it was under the hood. You had to count flashes of the light. https://www.matthewsvolvosite.com/how-t ... -obd-unit/
OBD-II arrived in 1995 on some Volvos, and 1996 on the rest. That's scanner stuff.
postoak
- Year and Model: 2007 XC90 V8 Sport
- Has thanked: 1 time
Sounds like you've addressed a lot of the heavy hitters already (fuel pressure regulator, spark plugs, cat converter). Careful with the MAF, esp if you're thinking of buying new. They're all made in China crap, and you're better off finding a used known working one instead. ECU would be last resort.
For the cat, is it new and CARB / 50-state compliant? If so you must've spent a pretty penny with current prices being heavily inflated - ouch.
Does your coolant temp register on the dash? If so, you're prob good there in regards to the coolant temp sensor.
Check your idle CO mixture (check this thread: http://forums.turbobricks.com/showthrea ... 002&page=1). 86 MAF's (LH 2.2) have the mixture screw, so it helps to check if you're running rich at idle.
How's your O2 sensor? Any exhaust leaks? Have you plugged the hot air tube on the filter box? Make sure to leave the flexible pipe in place to help with passing visual inspection.
