Position ECT Sensor in XC70
Deevolvo
Year and Model: 2006!XC70
Post by Deevolvo »
Hello Volvo experts,
Can you tell me where I can find the ECT sensor (Engine Coolant Temperature) in the XC70 from 04/2006 ?
Will appreciate pictures or a nice description about the installation location.
Thanks a lot in advance.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Look by the fuel rail, there's a connector plugged into the ECT. ECT itself is mounted into thermostat body, between the rail and power steering pump.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
I posted it here.
By the time you need to replace the ECT (usually > 120K miles), you may as well replace the whole assembly,
which includes the tstat + ECT in one device:
DIY: 2005 Volvo XC90 Thermostat + ECT without removing PS Pump
viewtopic.php?t=79031
Deevolvo
Post by Deevolvo »
Thanks guys for the quick and helpful answer
vtl
Post by vtl »
Wahler has t-stat inserts, they are much cheaper than a t-stat assembly.
Post by cn90 »
If Wahler has tstat insert, this is new to me...
Has thanked: 2203 times
Been thanked: 1852 times
There are 2 thermostat bodies and a chassis/engine break. The earlier one you can replace the thermostat only, the later one you have to replace the whole assembly. I will qualify this in that I did see someone managed to fit a new thermostat in the later body but had a nightmare getting it to fit and work.
