Hello everyone,
My ABS light is coming on intermittently and my speedo sometimes doesn't work. Knowing this was a common ABS module failure item, I sent my previously rebuilt module to Midwest ABS repair. He checked it out and it had no issues and no stored fault codes. Reinstalled and the symptoms continued...
Assuming the next issue was ignition switch, I replaced the electric portion with a new Volvo part... Still not fixed.
I'm hearing this is since both the ABS module checks out fine and the switch has been replaced, the likely caused by a power related issue between the cluster and the ABS module. Unfortunately I can't find any "next steps" to proceed with the troubleshooting.
Does anyone have any further suggestions? Thanks in advance.
Clarke
1998 S70 GLT - ABS light and Speedo issue (Not ABS module)
- clarkerussell
- Has thanked: 20 times
- Been thanked: 4 times
- Has thanked: 1850 times
- Been thanked: 1712 times
Have you checked your ABS cables and connectors for continuity and resistance as well as the reluctor rings for rust damage or cracks?
I would check the front for this over the rears as with a bad or no signal it will take out your speedo as well as that is where it gets its speed signal from. Be careful with the ABS cables as they can look ok but be broken internally.
surfbug1
- Year and Model: 1998 V70, 2006 S80
- Has thanked: 41 times
- Been thanked: 9 times
Interested in how this turns out.
I have the same problem, but have not sent in my ABS unit yet.
Speedo will work some days, and then nothing for a few days weeks kinda thing.
And the ABS light comes and goes with the speedo working.
I'm gonna chase the abs cables...what is the reluctor ring?
Other than replacing the ABS cables, how do u check if they are cracked on the inside?
Got a C3 Corvette corvette for sale? 1968 to 1981...not the 1982 crossfire injection
Ping me!
Ping me!
The reluctor ring is the toothed ring on the outer ends of the axles. The ABS sensors look for the gaps in the teeth to know if the wheels are moving at the same speed, but also use them for reading the car's speed. They can corrode, fill up with debris, rust so teeth cannot be differentiated and also crack. All will cause issues for speedo and ABS even if the sensors and cables to the ABS are good.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 93 times
- Been thanked: 146 times
https://midwest-abs.com/troubleshooting
Good stuff about simple sensor testing
towards the bottom of the linked page.
- Has thanked: 1505 times
- Been thanked: 3818 times
Is there deep knowledge on which sensor is used for speed input to the speedometer? I recall a UK document had this
Reluctor ring, also commonly called a tone ring
surfbug1
Ok cool. That helps.
The speedo works sometimes, but the abs light won't turn on and off with that little switch on the dash! Or is that a traction light ..."TRACS"
that thing won't switch on and off no matter what.
Defe the abs module? I should send it out?
Ping me!
Ping me!
ABS is always on, the TRACS light turns off the traction control system only, it turns back on by default on startup
Talk to mattymoo (email or phone) about your symptoms. I’m still trying to relearn how the speedo gets it data
Inspect your front abs sensors and wires for any damage. Replace anything that isn’t pristine.
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
Anything errant coming from any of the wheels that is enough to cut out the speedo would have set an absolute minimum of two codes, which would be open circuits on both front wheels.
With your regular faulty module you would have an absolute minimum of nine stored codes to reach that point, but the usual is 13. an extrapolation/wrong wheel speed code for each wheel plus an open circuit and one speed signal code.
Anything causing no speedo but with no codes is going to be communication. No power would usually set an internal relay code on a 96-98. This almost always leaves either the ignition switch or the link between the module and cluster.
Then from there we can add other nonsense that frequently pops up. 99-2000 clusters installed in a 98 or vice-versa, drunken "master mechanic" uncles that "touched" something. Missing grounds, some rigged trash electrical work, aftermarket wheel sensors, etc.
There's about 10 other things I'm missing.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
- clarkerussell
Can 850OBD-II program pull ABS fault codes?
- 1029 Views
Last post by Matty Moo
- 550 Views
Last post by RedBrickCollector
