850 bumpin and knocking, but where is the noise comming from Topic is solved
Gabewillwin
i have a 1997 850 and recently the car has been making a kinda bump knock sounds comming from what seems to be the front pass side wheel well. All the brake components are new and nothing seems loose, but i know how sound carries under a car. The noise happens mostly when the car is being aggitated (a bump or a dip) but on occasion happens under normal driving conditions. Any one have any ideas...the sound is driving me nuts!.
Gabewillwin
i should mention that the car has 153 K on it and has the origional auto in it..and is in preatty good shape.
White850Turbo
- Year and Model:
Sounds like a broken spring seat to me since you said it mainly happens when driving over bumps/dips. https://www.matthewsvolvosite.com/spring_seats.php <-- This page shows what happens.
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
- Tsquared
- Year and Model: 11 C30
The spring pad on the McPhearson strut could be worn out or torn loose. I had the rear lateral sway bar break on my 850 at 65K - the knocking it was making sounding like front suspention.Gabewillwin wrote:i have a 1997 850 and recently the car has been making a kinda bump knock sounds comming from what seems to be the front pass side wheel well. All the brake components are new and nothing seems loose, but i know how sound carries under a car. The noise happens mostly when the car is being aggitated (a bump or a dip) but on occasion happens under normal driving conditions. Any one have any ideas...the sound is driving me nuts!.
Get it on a platform lift so that the suspention is compressed and you can inspect it from the bottom.
Let us know what you find out.
TT
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
Gabewillwin
Thanks guys, post vacation (leaving tommorw!!) ill put it on a lift and see what is to blame..both explainations seem totally on par, only time will tell
