850 bumpin and knocking, but where is the noise comming from
Gabewillwin
Post by Gabewillwin »
i have a 1997 850 and recently the car has been making a kinda bump knock sounds comming from what seems to be the front pass side wheel well. All the brake components are new and nothing seems loose, but i know how sound carries under a car. The noise happens mostly when the car is being aggitated (a bump or a dip) but on occasion happens under normal driving conditions. Any one have any ideas...the sound is driving me nuts!.
Gabewillwin
i should mention that the car has 153 K on it and has the origional auto in it..and is in preatty good shape.
White850Turbo
Year and Model:
Post by White850Turbo »
Sounds like a broken spring seat to me since you said it mainly happens when driving over bumps/dips. https://www.matthewsvolvosite.com/spring_seats.php <-- This page shows what happens.
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
Tsquared
Year and Model: 11 C30
Post by Tsquared »
Gabewillwin wrote:i have a 1997 850 and recently the car has been making a kinda bump knock sounds comming from what seems to be the front pass side wheel well. All the brake components are new and nothing seems loose, but i know how sound carries under a car. The noise happens mostly when the car is being aggitated (a bump or a dip) but on occasion happens under normal driving conditions. Any one have any ideas...the sound is driving me nuts!.
The spring pad on the McPhearson strut could be worn out or torn loose. I had the rear lateral sway bar break on my 850 at 65K - the knocking it was making sounding like front suspention.
Get it on a platform lift so that the suspention is compressed and you can inspect it from the bottom.
Let us know what you find out.
TT
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
Gabewillwin
Thanks guys, post vacation (leaving tommorw!!) ill put it on a lift and see what is to blame..both explainations seem totally on par, only time will tell
