Oil Change Standard or Synthetic?
AC Clutch Gap Magnetic Fix - Breadclip Alternative
dcunited122
I need an oil change soon, should I make the switch to synthetic? Pros and Cons? Thanks
White850Turbo
- Year and Model:
The old rule applies here: You get what you pay for. There's a reason synthetic costs so much more; it's that much better. I won't go real deep into anything here, but I'd suggest checking out the forums on BITOG. Synthetic is better for your car in every way.
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
The talk about synthetic has been pretty well all positive. I think if you run your car really hard you would probably want all of the protection you can get. I have also seen 4 cars to date that have over 400,000 miles on them and they have never seen a drop of synthetic oil in them. My advice is whatever you chose, stick with it and don't keep swapping back and forth. As an engine builder, I use only natural oil. I also change it frequently along with fliters and keep a close eye on those engines as they have alot more $$ and power in them then my Volvo family wagon.
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
- Has thanked: 2664 times
- Been thanked: 1256 times
While I use Mobil 1 in my 850, didn't they downgrade the formula about two years ago? "Watered it down" a bit compared to what it's traditionally been?
I remember reading something about that and how they tried to spin it off as "improved."
- Tsquared
- Year and Model: 11 C30
If memory serves me, they re-adjusted the levels of paraffin and molybdenum. Both of these are additives to increase the life of the oil. If I can run down the link on it I will post it.
Any way you look at it synthetic is always better than dyno oil - even blended syn is better than strait dyno. The key thing with any oil is to perform the routine maintenance.
BTW: I use Mobile 1 in everything I have - I have found it to be the best synthetic for the $$
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
