Oil Change Standard or Synthetic?
This topic is in the MVS Volvo Repair Database » AC Clutch Gap Magnetic Fix - Breadclip Alternative
dcunited122
Post by dcunited122 »
I need an oil change soon, should I make the switch to synthetic? Pros and Cons? Thanks
White850Turbo
Post by White850Turbo »
The old rule applies here: You get what you pay for. There's a reason synthetic costs so much more; it's that much better. I won't go real deep into anything here, but I'd suggest checking out the forums on BITOG. Synthetic is better for your car in every way.
-Sean
1998 S70 T5 (Almost Stock)
turbotim2
Post by turbotim2 »
The talk about synthetic has been pretty well all positive. I think if you run your car really hard you would probably want all of the protection you can get. I have also seen 4 cars to date that have over 400,000 miles on them and they have never seen a drop of synthetic oil in them. My advice is whatever you chose, stick with it and don't keep swapping back and forth. As an engine builder, I use only natural oil. I also change it frequently along with fliters and keep a close eye on those engines as they have alot more $$ and power in them then my Volvo family wagon.
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2662 times
Been thanked: 1256 times
Post by matthew1 »
While I use Mobil 1 in my 850, didn't they downgrade the formula about two years ago? "Watered it down" a bit compared to what it's traditionally been?
I remember reading something about that and how they tried to spin it off as "improved."
Also -> Amazon link
Tsquared
Year and Model: 11 C30
Has thanked: 1 time
Post by Tsquared »
If memory serves me, they re-adjusted the levels of paraffin and molybdenum. Both of these are additives to increase the life of the oil. If I can run down the link on it I will post it.
Any way you look at it synthetic is always better than dyno oil - even blended syn is better than strait dyno. The key thing with any oil is to perform the routine maintenance.
BTW: I use Mobile 1 in everything I have - I have found it to be the best synthetic for the $$
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
