Volvo S70 Abs And Traction Control Light On
ZAPODLO
Post by ZAPODLO »
:cry: I HAVE 1998 VOLVO S70 AND FOR NO RESON MY TRACTION CONTROL AND ABS LIGHT CAME ON AND DONT WANT TO TURN OFF I CHECKED FUSE FOR ABS AND THEY ARE OK BUT I CANT FIND FUSE FOR TRACTIO CONTROL ANY BODY KNOWS ANYTHING OR HAD SAME PROBLEM PLEASE LET ME KNOW THANKS
White850Turbo
Year and Model:
Post by White850Turbo »
Have your codes read, but the most likely problem is a faulty ABS unit. Check here for more info.
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
RajLives
Post by RajLives »
I'm new to volvo's, and I just got a brake job, brakes, rotors, etc. for the front and rear. Today I drive it to work and the Tracs off light came on and then a couple minutes later the ABS light came on. Is this possibly somehow related to the brake job.
Thanks
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2655 times
Been thanked: 1248 times
Post by matthew1 »
Yes. Remove wheels and check your wheel speed sensors for dirt/debris. They are the near the hub and are the only item near there with an electrical wire leading to them.
Or call the shop and ask them to do this.
Also -> Amazon link
FrustratedVolvoOwner
Post by FrustratedVolvoOwner »
:evil:
I too just had rear brakes replaced on a 1998 S70. The ABS and TRACS light are both now on too! The ABS sometimes activates at low speeds and is quite a surprise when it happens. Oh, by the way, the car only has 56000 miles on it....The shop where I've taken it says it needs to be "diagnosed." They are quoting about 350 - 600 for repairs to the ABS control unit, plus labor of 72/hr. The code indicates that it is a right rear ABS sensor that is faulting. Could this have been caused during a brake pad change?
Thanks.
White850Turbo
Year and Model:
FrustratedVolvoOwner wrote::evil:
Thanks.
You mean the right rear wheel sensor? If so, check to make sure the monkies at the brake place didn't dislodge the sensor and that the contact points are clean. If so, a brand new wheel sensor shouldn't cost you more than $100 and can be installed in 10 minutes including dismounting of the wheel.
-Sean
malum
Year and Model:
Post by malum »
according to mr Volvospeed
http://www.volvospeed.com/Repair/abstrax.php
In the last five years I have seen one bad wheel sensor, and hundreds of bad control modules. If a repair shop should replace your wheel sensors and your problem returns, ensure that the cost of that repair (parts and labor) is carried over to what it takes to really fix the car.
I just had mine in for ABS light and the code read faulty right rear sensor and faulty ABS unit. The guy at Volvo said that in his experience it's hardly ever the sensor so I had them replace the ABS controller.
It was expensive (I am in the UK and everything here is expensive)
Joey
Post by Joey »
I disconnected the negative cable on the battery on my 98 S70 to clean out the flame trap, (all that went well). Then when I reconnect and restart and drive the car the ABS and TRAC lights come on and stay on....?? Did I burn it up or does anyone have any insight on this one? Thanks much!
VolvoXC70
Year and Model: xc70, 1998
Post by VolvoXC70 »
Hi Matt,
I have the same problem. How would I "remove wheels and check wheel speed sensors for dirt/debris. They are the near the hub and are the only item near there with an electrical wire leading to them".
Thanks.
matthew1
Site Admin
Post by matthew1 »
Since 2005, when this topic was active, it's become apparant that 90+% of these are caused by bad ABS modules.
If you do want to check your sensors, what do you need help with? How to take off the wheel (do one at a time)?
Also -> Amazon link
