Yes, your pic shows the same FPR as in the pic I posted.
As per my post up above: your car still has an FPR, it is just not at the rail. Follow the fuel line backwards from the engine toward the tank, you will eventually find the FPR. On some it is located down near the steering rack, others all the way back by the fuel filter.
Or, are you saying you just want to replace the damper? I'm not sure what you mean by "can't find the part I need."
Volvo 850 GLT warm starting issue Topic is solved
- Has thanked: 293 times
- Been thanked: 765 times
Re: Volvo 850 GLT warm starting issue
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
TrevorVolvo
- Year and Model: 1995 850
Turns out the damper at the fuel rail failed and was releasing fuel into the intake every time I turned the car off.
Replaced with junkyard one, all is good!
Thank you for your time
Thanks for telling us what the trouble was, that's good to know. Happy driving!
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- 2809 Views
Last post by 93ForMe
- 632 Views
Last post by BlackyChan91
