98 v70xc Rear Hub Assembly/Bearing Topic is solved
Bdates
Year and Model: 1998 V70XC AWD
Post by Bdates »
Ok...
Today I decided to tackle the humming/buzzing noise coming from the rear right. First I thought it was the angle gear but I changed the fluid and the noise continued. Did some Youtube surfing and decided it was the hub.
Most importantly, this Volvo IS AWD, so it is unlike most, meaning the rear hub is different than a FWD.
Ordered the hub from O'Rileys, ended up being the wrong one. (No spindle for the drive shaft to connect to on in the center of the hub) So I checked Auto Zone and Napa and All three don't have the specifically AWD hub for the rear. They have bearings that are "compatible" but I don't trust it.
I ended up getting all the way to using a 3 hooked puller to remove the hub; also using PB Blaster. Not knowing that there was a retaining ring, I Separated half of the bearing and the hub, while leaving the other half of the bearing in the housing that holds the hub and bearing assembly. Imagine my frustration.
The retaining ring was insanely rusted.Took about an hour with PB Blaster, a flathead, and dental picks to remove it. Oh and a punch.
Anyway, now I am afraid I will have to remove the entire housing that connects the suspension to the hub and find a shop with a press to get the rest of the bearing out because I don't have one. However, even If I did that, the hub I removed still has part of the first half of the bearing race stuck on it. I'm at the point of not caring and just buying the entire hub and bearing assembly, but I can't find anywhere that sells the correct part, let alone a decent price.
Assuming I do find the correct part for my AWD, here are some pictures of my progress. I still need to remove this black line and the handbrake/e-brake cable as well as the rest of the major components of the suspension.
I removed the nut to this black cable, but I can't get it to come off and I have already banged on it without going to nuts on it in fear of breaking whatever it is.
As far as the E-brake cable, I tried to loosen it but at this point was to frustrated to keep trying to figure it out so I got a beer and put everything away for the night.
I'm sure It is easy to tell, but I know just enough to get into trouble... :roll:
Thanks in advance for any help!
Update:
I ended up breaking the bracket to the black wire, however the contents connected to it seem to be alright so ill probably and up epoxying the bracket back together when I reassemble.
I finally figured out how to get the e-brake cable off... took a while but thats just because of my inexperience.
Taking the knuckle and hub to get the bearing race pressed out of the knuckle and the rest of the race on the hub removed somehow...
Update #2:
The auto shop on base is amazing and the workers are awesome. I pressed the bearing out of the knuckle and cut the race off of the hub for free.
Now I just have to find the correct bearing. As I said earlier I dont trust the shops in town and cant seem to find a decently priced one online. Any suggestions?
Update #3:
I ended up measuring the old bearing to reference it with the auto parts stores with a dial caliper.
Approximate dimensions:
45mm inside diameter
84mm outside diameter
39mm width
Napa's bearing part # is PGRW219 for around $55.
Auto Zone had one in stock, but I did not get the part number. It was around $58
O'Riley's also had it in stock. "MasterPro" part# PT513130 It was around $57
I went with O'Riley's just because it was my last stop.
2000 s40 (Sold)
1998 v70xc (Deceased)
1991 Mercury Capri XR2 (Sold)
2001 Mazda 626 ES (Wife's old and Sold)
1998 v70 AWD (Sold)
1998 v70xc (Daily)
2005 Polaris Predator 500 (Sold)
2007 Kawasaki Prairie 700 (Sold)
2008 Ford Escape Hybrid (Wife's)
2007 Yamaha vStar 650 Custom (Sold)
2006 Kawasaki Z1000 (Sold)
2016 Yamaha FZ-09 (Toy)
2015 Honda CB300F (Wife's Toy)
Has thanked: 1505 times
Been thanked: 3818 times
You could try finding your balls with solvent, and repacking them with good moly grease, and reinstalling the hub. ( I know that sounds too personal. :-)
They look in great shape. If the noise was subtle, that might give you another 50,000 miles
Those bearings are really overbuilt for that application
:thumbsup: to Volvo
Bdates
Post by Bdates »
Any advice on how to remove the e-brake cable?
2000 s40 (Sold)
1998 v70 AWD (Sold)
1998 v70xc (Daily)
Alas , I have not an AWD in my fleet, so I'm not useful there
Neil has done the most back axle work here, so let others chime in
Bdates
Post by Bdates »
Update:
I measured the inside, outside, and width of the bearing and was able to find one in town. $57 bucks or so. I then hydrolic-pressed it in at the shop on base and put everything back together.
The black cable is pretty snug back in its hole in the knuckle... so I am not very worried about it falling out. There are no check engine lights for it so I must not have broken anything except for the bracket holding it in place anyway. I will be checking on it periodically.
Before I started this project the noise started around 35mph, and I test drove it today up to 50mph and the noise didn't come back, and it was a pretty noticeable noise so I guess I fixed the problem!
I hope this helps someone in the future considering the lack of AWD knowledge there is on here.
Cheers!
2000 s40 (Sold)
1998 v70 AWD (Sold)
1998 v70xc (Daily)
Can you post up make and part number for reference please ?
I'll mark fir VRD
Bdates
Post by Bdates »
Sure abscate, just updated it.
2000 s40 (Sold)
1998 v70 AWD (Sold)
1998 v70xc (Daily)
