1999 V70T5M ME7 Ignition sequence
Has thanked: 1497 times
Been thanked: 3810 times
I was stuck in the car during a thunderstorm so I document the correct sequence of light-ups on keying on my 1999
Engine was not started during these tests.
POS 1 turns on SRS light for 5 seconds.
If you go direct to POS 2, all lights come on, then ABS burps after 2 seconds and goes out
5 seconds later SRS and ETS light go out.
Position 1 - SRS light only, goes off after 5 seconds
Direct to Position II - all lights go on
5 seconds after POS 2 - ABS goes off first, then SRS, then ETS
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
I have to check, but I think the 98' is a little different, I am not sure about the ABS burp.
Also, on mine the "service light" doesn't come on :o :lol:
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
The cruise light on the 99 never comes on in the key sequence. There is no way to test bulb function short of pulling the bulb from the dash. Maybe you can in VIDA
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
I believe you can turn it on in VIDA. I know the ABS light will blink while VIDA is accessing the ABS controller as well. We should check tomorrow :)
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Will have a 1999 Denso V70 in for service this week. Let's see if it mirrors that setup.
Thanks Mike. This info is a goldmine when you get that weirdness if something has changed but you aren't sure what...
G'day.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2650 times
Been thanked: 1240 times
Post by matthew1 »
abscate wrote: 08 Jun 2017, 09:35 I was stuck in the car during a thunderstorm so I document the correct sequence of light-ups on keying...
But did you drag and drop those photos onto the text box?
Just kidding, Steve :-). This is actually something I've never seen here, and it's very useful.
Also -> Amazon link
Interesting . If you start the car normally, the ETS and ABS go out on engine start, the SRS 5 seconds later. That ABS has me a bit puzzled.
Adding the immobiliser function to this thread
I had a key cut with chip that failed to take. It starts the car, which then stalls after 2 seconds. On subsequent attempts, it only cranks, but does not fire. Once the key is removed, and wait a few seconds, it will repeat the
crank - start- die in 2 seconds -crank/no-start condition.
I tried to get a key cut for my 2000 V70 and the guy said that the key code on the old chip was scrambled and his software couldn't read it. We ended up digging out the old chip and inserting it in the new key.
