front rotors and brake for 98 S70
A List of Volvo Paint Colors and Their Codes
carlos
What rotor and brake pads would you recommend for a 1998 S70. And what is the difference between using a 280mm or a 306mm rotor? Thanks in advance.
- Has thanked: 2660 times
- Been thanked: 1254 times
Whatever the dealers use. Going off-brand in any 850/S/V70 braking component is (IMO) the #1 cause of "wish I had used OEM materials."
Squeaks, rattles, dust, warping rotors... all symptoms of someone improving performance or saving money.
pfeener
- Year and Model:
- Been thanked: 2 times
It depends on what you're looking for. If you don't want to spend an arm and a leg stay with the 280MM rotors that are on your car now. I would go with either Brembo or Zimmerman rotors and genuine Volvo pads all available from FCP.
- jtp
- Year and Model: 99 v70R
- Has thanked: 11 times
- Been thanked: 10 times
The only volvo mechanic I kind-of know says volvo pads are a must or you end up with squeaking. I just had zimmerman rotors and volvo pads put on a couple of months ago, just before I bought my s70, and that combo has worked very well. These cars just brake incredibly well, especially when you're used to other makes.
99 V70R AWD
Almost 155K Miles
Breaking is how I know it’s working
98 S70NA (sold)
95 850 Turbo Wagon (RIP)
Almost 155K Miles
98 S70NA (sold)
Another vote here for the Zimmerman rotors. My S70 has had them on the front for well over 30k miles now. Very satisfied. Used aftermarket pads, however. Seems to increase rotor life and definitedly has less dust. You do get that bit of squeal, however.
3 Volvos: '96 S90: 70k, '00 S70: 126K, '90 740: 139K
warrenswagon
- Year and Model:
I just put ATE rotors and Remsa full Ceramic pads on about 5000km ago. Absolutely no squeel and GREAT braking, continue to grab harder as they heat up. I did use ATE and OE pads on the back and again no squeel.
- 1988 Views
Last post by fishingdad101
- 810 Views
Last post by regent
