2000 s70 automatic transmission Topic is solved
chubby1975
Year and Model: 2000 S70
Post by chubby1975 »
I own a 2000 S70. I cannot find the transmission dipstick or where to put the transmission fluid in. Please advise!! Thanks
Has thanked: 1505 times
Been thanked: 3818 times
Volvo manuals are free online, see here, Chapter 8 , Underhood
https://volvo.custhelp.com/app/manuals/ ... /om_id/842
Herb Goltz
Year and Model: 04& 06 XC70, '12 s60
Been thanked: 3 times
Post by Herb Goltz »
Be sure to check what type of transmission fluid you need-- the normally-aspirated cars have the 5 sp auto, the turbo still has the 4 sp (unless the car is an R model). The 5 sp needs JWS-3309 compliant fluid, which includes Toyota IV fluid, which is much cheaper.
The stick is tiny and yellow and is pretty well concealed by things above it.
2012 s60 t5
2006 XC70
2004 XC70
Has thanked: 1848 times
Been thanked: 1710 times
Dipstick is hidden under the wiring harness below the air intake snorkel. Remove the snorkel at the right side of radiator (when viewed from the front of the car) to the air box. Then look down the side of the radiator and you will see the wiring harness running diagonally to under the radiator. Beneath that you will see a short yellow dipstick. It is held in by a spring clip which you need to push back to remove.
You fill oil through the dipstick hole. I use a clear plastic tube attached to a small funnel and it needs to be filled slowly.
Check oil when transmission is hot only. cold reading is not very accurate.
Be careful with the dipstick as the get brittle with age. I broke mine and had a devil of a job fishing the remainder out of the hole!
I am assuming like the guys said it is a non-turbo model (base/NA) with the 5-speed. If it is an 'R' it is a challenge to get too as you have the turbo pipework in the way.
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 73 times
Post by FlyingVolvo »
scot850 wrote: 18 Oct 2018, 08:06 Check oil when transmission is hot only. cold reading is not very accurate.
Worth also noting that it needs to checked with the engine running, on a level surface. I agree with checking it hot.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
