Front Right side noise after wheel hub replacement OBQ SKF BEARING!) Topic is solved
Fiodor
Year and Model: 1997 V70 2.0 T5 AWD
Has thanked: 13 times
Been thanked: 9 times
Post by Fiodor »
Hello,
After replacing my wheel hubs on both front wheels I now have a low tone noise coming from the right that turns into a high pitched noise when I take a very hard turn to the left.
Any ideas ?
Thanks for your help !
1997 V70 T5 2.0 AWD with welded angle gear at 240k km
1990 740 Break (dead)
Has thanked: 292 times
Been thanked: 765 times
From that description it sounds like a bad hub bearing on the right. What's the bearing source?
Did you check and make sure nothing is stuck, for example behind the brake pads?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Fiodor
Post by Fiodor »
It's an SKF bearing.
We didn't find anything behind the brake pads
Hmmmm also are you sure the axle is seated all the way in the hub? Though you never know of course, SKF should be good.
'06 S60 R, 197k
Fiodor
Post by Fiodor »
I'll check on Monday, I left my car at the mechanic
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
Fiodor wrote: 24 May 2019, 12:24 I'll check on Monday, I left my car at the mechanic
A swap may help diagnose OR clear the issue. Wheel alignment is a good idea.
Fiodor
Post by Fiodor »
Well it sure took a hell of a time but it eventually got fixed.
It was a bad wheel hub out of the box...
Has thanked: 1497 times
Been thanked: 3810 times
Obq is industry speak for out of box quality
