SOLVED! Power cut at 4k rpm in 3rd gear 97 850 T5 Topic is solved
smallblackbrick
Year and Model: 1997 850 T5 Sedan
Has thanked: 3 times
Re: SOLVED! Power cut at 4k rpm in 3rd gear 97 850 T5
Post by smallblackbrick »
Clemens wrote: 21 Oct 2022, 16:07 +1 on the CBV.
Also, a worn beyond repair 15G can easily reduce the max. boost. Ask me how I know. You can usually tell by longitudinal movement of the blade and shaft with the fresh air pipe removed.
I've definitely been worried about this, thanks for the tip on how to check wear. The turbo is just covered in 1/4' of oil. Might steal my buddies 15g from his R he put a 19t in. Since I'm already doing that work, and badly overdue for a new exhaust, would you say going to a bigger turbo is worth it?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2650 times
Been thanked: 1240 times
Post by matthew1 »
Could be MAF also, but whatever the case you're looking at unmetered air getting into the system... so back to my meme, or CBV, or dead turbo... the culprit is the air component of the 3 things you need for combustion: air, fuel, spark.
smallblackbrick wrote: 21 Oct 2022, 21:20
matthew1 wrote: 21 Oct 2022, 13:12
smallblackbrick wrote: 21 Oct 2022, 12:35Now to deal with the fact that my turbo is underboosting now -_-.
I just made this meme for you.
riddle me this
I did tcv lines already, the guy before me had them plugged in all wrong or not plugged in, and used 8mm ID rubber :lol:
Just ordered IPD TCV, Bosch IAC, and a MAF meter. If I ship of Theseus this car it should run well.
Also -> Amazon link
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
smallblackbrick wrote: 21 Oct 2022, 21:23
A 18T or 19T surely pumps up the fun factor, but you have to be aware they call the 19T "The Rodbender" for a reason. A 19T calls for a new tune. It's mandatory. And you still risk screwing up your internals and the AT. A M56 swap is surely nice and smart for a 19T. At least reliability and long time usability are on your list.
Also, your car should really be as close to stage 0 before increasing the torque and hp output.
If I could get my hands on a functioning 15G I'd go that route if yours is shot.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Has thanked: 1497 times
Been thanked: 3809 times
13141.59MVS points awarded for the Reference, 10,000 standard award and 3141.59 in interest from 2022
