P80 comprehensive tabulation of Obsolecent parts No longer available (NLA)
Has thanked: 1505 times
Been thanked: 3818 times
I keep on meaning to start this thread.
Let’s make an entry with each volvo part number in title for search
Three stages of obsolescence proposed for p80s
Stage 1 - no longer available from Volvo, but good aftermarket available
Example Volvo ac compressors. Nissens aftermarket
Stage 2 - no longer available from Volvo , sketchy aftermarket, junkyard used parts available
Stage 3 - hard to find. No Volvo, aftermarket , junkyard rare or overpriced
Example. HVAC manual climate control head unit
https://www.fcpeuro.com/products/volvo- ... vo-9181324
9181324 stage 3 ?
Clutch hose from clutch master cylinder to release bearing NLA from Volvo, no aftermarket.
I would save the end fittings on an old line as this is a critical replacement part.
Skandix shows three pieces in stock today, might be last ones
1998-2000 V70 S70 MCC control unit is NLA. People jack the price of these on eBay. Try to avoid encouraging this.
If your cable head is broken you can disconnect the cables and operate manually under the dash until you find one.
Thread
viewtopic.php?t=87159&start=10
FCP sells the Proforma rebuild for about$350
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
Excellent public service post!
1998-2000 awd models
Eccentric bolt for panhard rods NLA stAge 3
Rear wheel brake backing plates NLA stage 3
Parking brake clips for awd NLA byte there are non Volvo parts thst fit
Massive thread on awd suspension parts here
( to be linked)
1998-2000 brake medal position Sensor
Part
Stage 2
Mounts on brake booster and reports pedal position to ECM
Can be opened and cleaned
11-2025 available at FCP $115
jmartin919
Year and Model: S70 GLT SE 2000
Has thanked: 94 times
Been thanked: 39 times
Post by jmartin919 »
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
On a whim I searched Amazon for Volvo parts. I found a mix of name brand parts of all types and a lot of off brand parts. Although quality may be suspect, some of the NLA parts may be available form China sources. I have found many serviceable parts for small engines available from China.
Desperate times call for desperate measures.
MarinerMan
Year and Model: 1999 V70 N/A
Been thanked: 6 times
Post by MarinerMan »
jmartin919 wrote: 28 Nov 2025, 06:51 Is this the part? https://www.fcpeuro.com/products/volvo- ... Em#fitment
That is the part specifies that it is for STC (stability traction control) vehicles. There is also the TRACS vehicles and those that have neither STC or TRACS. Does anyone know if they all use the same component, or are they different?
Steering coupler between steering column and power steering rack nla.
No aftermarket
Junkyard only
