P80 comprehensive tabulation of Obsolecent parts No longer available (NLA)
Has thanked: 1505 times
Been thanked: 3818 times
Re: P80 comprehensive tabulation of Obsolecent parts No longer available (NLA)
MarinerMan wrote: 28 Nov 2025, 17:42
jmartin919 wrote: 28 Nov 2025, 06:51 Is this the part? https://www.fcpeuro.com/products/volvo- ... Em#fitment
That is the part specifies that it is for STC (stability traction control) vehicles. There is also the TRACS vehicles and those that have neither STC or TRACS. Does anyone know if they all use the same component, or are they different?
My memory banks were foggy on this, I thought they were the same and it looks like you can still get this part
AI generated list of th8ngs to scavenge from junkyard visits.
Not all of these are NLA
Exterior & Lighting
Volvo branded headlights (especially glass 850/S70/V70)
Volvo branded corner/turn signals
Volvo branded taillights (pre-LED eras)
Volvo branded fog lights + fog light grilles
Door puddle / courtesy lights
Center wheel caps / hub covers with Volvo logo
Headlight wiper arms & motors
Small trim rings for fog light installation
Interior & Comfort
Retractable cargo cover/shade (wagons)
Complete third-row seats + belts & hardware (V70/XC70, especially heated) :)
Heated rear seat elements & switches
Shift knobs (wood, leather, manual or auto)
Center console armrest lids (good condition)
Rear A/C console vents & panels
Volvo logo floor mats & cargo mats
Suspension & Drivetrain
Front lower control arms / torque arms (especially AWD)
Complete CV axles (especially AWD)
Rear trailing arms (if not rusted out)
Electronics & Audio
SC-800 / SC-801 / SC-900 / SC-901 radios
All factory amps (trunk & under-seat HU-series)
Fiber-optic amp-to-radio cables & connectors
ABS control modules (working = gold)
ECC climate control heads
SRS airbag modules (non-deployed)
Engine Bay Sensors & Ignition
Mass Air Flow (MAF) sensor
Camshaft position sensor
Crankshaft position sensor
Throttle position sensor / ETM (good contacts, especially contactless or rebuildable by Xemodex)
Engine Coolant Temp (ECT) sensor
Ignition coils
EVAP purge solenoid
Barometric pressure sensor
Lateral accelerometer (DSTC cars)
Vacuum elbows & hoses
Fuel System
Fuel pump + sending unit assembly
AWD fuel tank vent pipes & breather
Fuel level sending units (especially older sliding cylinder type)
Pink or white fuel pump relay
Other relays (general, hit-or-miss but worth grabbing)
Miscellaneous Must-Grabs
Factory Volvo jack & tool kit (1998+)
Tailgate/hatch lift struts (still hold pressure)
All four wheel speed sensors + pigtails
Battery hold-down bracket & tray
AWD angle gear vent tube
Roof rails & factory crossbars (XC models)
Other plastic trim & bits in good shape
Has thanked: 1850 times
Been thanked: 1710 times
I appreciate all the work that has gone into generating this list. Unfortunately, this lists is only getting longer by the day, especially on the AWD cars. I would suggest that limiting the parts to keep only to OE Volvo parts may prove to be a little short sided. What about OE parts supplier parts like Bosch or others? These may end up being the godsend in future years.
Pre1999 1992-1998 turbo snorkel is NLA from Volvo part number Volvo Air Intake Hose - Genuine Volvo 9186200
D088 option is $300 as of Jan 2026
This also means the PTC orfice part of the crankcase system is also NLA , so treat the part and it rubber grommet like you love it, or at least like $300
Good junkyard harvest part !
The 1999- snorkel is still available new and I will document sizes here for potential compatibility.
