Bad bulb indicator on when braking.
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 24 times
96 855 the bad bulb indicator comes on when i touch the brake pedal but all bulbs appear to be intact/working. Possibly volt/watt problem with one of them? I switched a few around still happens though. External appearance suggests all bulbs are equally bright. More annoying than a functional problem, of course!
- Has thanked: 1848 times
- Been thanked: 1710 times
Is the high level brake light working? Can't recall on the 850 if there are any dual bulbs. It could be one is going bad and throwing when the brake is being used.
The systems can sometimes not like some brands of bulbs. I know my local dealer service manager (and master tech) says they regularly get issues that are down to bulb quality in aftermarket replacements. Changing the bulb usually fixes the issue.
454cid
- Has thanked: 145 times
- Been thanked: 129 times
When that happened to me, it was the 3rd brake light. It was intermittent.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- CIK7
- Has thanked: 327 times
- Been thanked: 87 times
So, I had an almost bad bulb on the rear with that light coming on. I replaced it. It went off. Then I decided to replace all the brake lights and reverse lights with LEDs and that light came back on. What's tripping it is the lack of power being drawn. Those light bulbs are supposed to draw, I think, 55 watts or 25 watts, something like that. LED bulbs only draw maybe five watts I thithink.
Jotunn77
- Year and Model: 97 855t - 91 945t
- Has thanked: 6 times
- Been thanked: 4 times
I had to replace the brake light switch when I had this problem. I was chasing the issue at the rear end of the car like yourself, switch bulbs and checking wiring with no solution. Ended up being a simple switch under the brake pedal. FCP and IPD have them.
1997 855 T5 - 297k
1991 945T - 121k
1991 945T - 121k
