I’ve got a couple sets of 15 inch and 16 inch wheels and rubber, can I graduate ftom a post it note onthe dash with new Speedo calibrations somehow? Is there a VIDA adjustment possible ?
Written wearing a 75 pound Labra-Dane lying on me, bonding after a business trip
P80 1998 1999 2000 DIM CDM calibration for tire/wheel size possible
- Has thanked: 1497 times
- Been thanked: 3810 times
- Has thanked: 1836 times
- Been thanked: 1709 times
Why are you needing to calibrate the speedo? With the correct tires, the speed would be the same as they would have the same rolling circumference.
15" wheels (been a while since I used those) had something like a 195/60/15 tire (I may be wrong and winters had a 185mm recommended), but I ran up to a 205.
16" is where Volvo made a change to the tire recommendation after a number of complaints of sidewall damage and changed the tire from a 50 to a 55 profile tire. No speedo calibration change was made.
The other issue is people using tires for a V70 XC on a standard V/S70 which had a taller sidewall. That will throw off the calibration a bit. There are several websites that you may be aware of that compare tires and the affect on indicated speeds. This website also lists variants for P80's:
https://www.wheel-size.com/size/volvo/v70/1998/
Neil
Neil
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 128 times
I think that's the issue. The tires aren't the OEM size for the car, but he's wanting to use them up without having to remember his speedometer is a bit off. I've been in this same situation with my Cadillac. I have Deville rims/tires on my CTS so I have to remember I'm going slightly faster than the speedometer is telling me. I got a great deal on the combination, for the rims, and didn't want to waste the tires. This coming spring, I'll likely get new tires because I want to return to the factory ride (higher aspect tires are a bit floaty) and accurate speedometer.
This might be something that 850OBD2 app can do. There are several newer features that saw last time I used it, but have not explored. Right now, I'm not connected to my car so poking around is kind of limited.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
This typically not a problem for me. I never wear a set of tires out any more with the low mileages we drive now we are retired. Bigger issue is they rot out long before they wear out!
