Vacuum tree wiggle- 98 S70 T5
veezmachine
- Year and Model: 1998 S70 T5
- Has thanked: 2 times
- Been thanked: 2 times
Hey all, was wondering if anyone else noticed that the vacuum tree on the manifold has a bit of wiggle/play to it even when tightened down? Asking because I've snapped 2 bolts before trying to get it tight on there (and managed to get them both out thankfully), but I wanted to make sure that I was in the right area by leaving it after just hand-tightening. I can't find any torque specs for it, so I wanted to double chekc. Thanks!
- Has thanked: 1506 times
- Been thanked: 3820 times
That needs to be firm to seal against vacuum leaks. Check the gasket and see if there is nastiness thereveezmachine wrote: ↑31 Jan 2026, 14:23 Hey all, was wondering if anyone else noticed that the vacuum tree on the manifold has a bit of wiggle/play to it even when tightened down? Asking because I've snapped 2 bolts before trying to get it tight on there (and managed to get them both out thankfully), but I wanted to make sure that I was in the right area by leaving it after just hand-tightening. I can't find any torque specs for it, so I wanted to double chekc. Thanks!
Just a wrist torque on those bolts, don’t gorilla them. M6 so 10 ft lb is plenty
- Has thanked: 1853 times
- Been thanked: 1712 times
Been a long time since I removed a vacuum tree. Does it not have an O-ring on there where it bolts down? If it does, it does not have to be cranked all the way down hard. Are the bolts too long so bottoming out before getting the tree tight?
