Hard cold start. Engine rough running for about to seconds, then fine. Temp gauge on dash normal.
At 37F ambient , ect connector shows infinite ohms, open circuit
Off we go , tools used
T40 torx thermostat cover bolts
9/16 fluted extractor socket
T27 torx cam cosmetic cover bolts
19mm open end
Pb blaster
Mapp gas
New ect sensor
2 new bolts
1999 RN ECT replacement Evita. 271644 2x 986228
- Has thanked: 1497 times
- Been thanked: 3809 times
T 27 and clips release the cover, nice access on the RN motor
Bolts looked hood, so I put a bit of PB on them and they cracked….. but I grabbed the T40 R bit by mistake and snapped it off
Used Mapp to warm for 30 seconds and the 9/16 fluted extractor
Ect comes out with a 19 mm open end
Reuse those old bolts, no thanks
Lots of no seize on the bolts , top off coolant, and get Juno the dog to sign off on the paoerwork
New sensor showed 4300 ohms at 35-40F ambient
Volvo chart calls for something like this
- Has thanked: 1834 times
- Been thanked: 1709 times
I keep finding weird stuff on P80's all the time of variances I did not know of. I thought the 99 NA had an inlet CVVT solenoid. Was that only added to the NA motors in 2000?
I believe it’s
1999 NA no VVT
1999 SE GLT Xc70 T5 R turbo exhaust only VVT
2000 NA intake VVT
2000 turbo exhaust VVT
- jreed
- Has thanked: 352 times
- Been thanked: 192 times
Thanks for sharing the snapped off bit picture -- I appreciate the reminder to use strong bits!
That is a 'security Torx' with the hole in the middle - I think the only place you see them on Volvo is the MAF unit to housing bolts?
I just goofed and grabbed it from the kit, instead of the T40.
Its a Tekton, so lifetime warranty.
