Dash Gauges stop working?
black 98 S70
Post by black 98 S70 »
Anyone else have this problem? The dash gauges, specifically the analog gauges plus the outside air temp all stopped functioning, but everything else worked fine. The car was turned off and restarted and the problem went away. I think it is a problem in the gauge assembly but I am hesitant to tear into it unless I know for sure.
BTW- this is a 98 s70
volvomaniac
Post by volvomaniac »
There are a couple of gauge clusters on Ebay.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2656 times
Been thanked: 1248 times
Post by matthew1 »
Tap around different areas on gauge pod cluster. If you're lucky, the affected area will reveal itself by blinking affected lights...
Many times (search this forum) the headlight switch can get spotty, causing problems with pod cluster lighting. You might try pulling this out and inspecting.
