multiple codes & no reverse any help? Topic is solved
wagonman
Post by wagonman »
Thanks to your help I have been able to pull multiple codes from my '94 non turbo wagon from A-1 #313, A-3 #144, A-7 #122, 231 and B2#122
but my real problem is rough idle cold and no reverse it was working but now it's gone. I pulled the codes because I had the trans rebuilt but I did not change the solenoids, hoping to find some solenoid codes but they are not there. when I place the car in drive it will drive but I get quite a bit of vibrations with my foot on the brake any help as to where should I start?
again I thank you for your time and effort.
Nelson
wagonman
Post by wagonman »
ok Ive been reading and reading but I still don't know where to start should I start with the gear position sensor or the speed sensor? is the SL solenoid responsible for my lost reverse or is it the STH solenoid? please help me choose where to start... thanks
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2656 times
Been thanked: 1248 times
Post by matthew1 »
Hi wagonman,
I don't have any firsthand experience with trans problems, 'cept for flushing the fluid, so I can't help directly. However, I link to this http://www.babcox.com/editorial/ic/ic40238.htm, listed on my Links page, displays the word 'soleniod' 6 times; pretty good chance it will help in one way or another.
Also -> Amazon link
