oil cooler line replacement
This topic is in the MVS Volvo Repair Database » PCV System Repair on a Volvo 5-cylinder
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
I have a specific question re "Rectangular Seal" (The seal between the thermostat housing and the engine, PN 1366791)...
P.O. already replaced both oil cooler lines and O-rings at 140K. I am now at 160K and can see the oil leak in this area.
Can I replace the Rectangular Seal w/o disconnecting the oil lines from the thermostat? In other words, can I simply remove the 2 Torx bolts and replace the Rectangular Seal?
castconcrete
Year and Model: 1996
Post by castconcrete »
I seem to remember that others have actually recommended that the new cooler lines be installed into the thermostat before the thermostat is re-attached to the car...so you should be able to replace the thermostat o-ring in the manner that you are describing.
beigg
Year and Model: 850 97
Post by beigg »
yes you can
ugh smh 850 Turbo fridge
Post by cn90 »
Question for the gurus...
I have the rectangular seal from dealer, I am replacing the rectangular seal this weekend.
1. Can I do it simply by driving the front on wood ramps? In other words, I'd like to avoid jacking up the car, removing the RF tire etc.
2. Or I have to remove the RF wheel and expose the crank pulley area?
holler1
Post by holler1 »
I've only removed the thermostat through the wheel well. I don't think you can get to the thermostat bolts from the bottom. I could be wrong, but even if you can access them I don't believe you could get enough pressure on the Torx tool to turn them without risking stripping.
1998 Volvo V70 AWD 165000-R muffler, HD endlinks, boost gauge
2008 Ford Fusion AWD 107000
2000 Ford Ranger 4wd 172000
1991 Toyota Camry 160000#1
Previous: 1982 Volvo DL (240) 160000
1998 Tacoma, Fords (6), Dodge, Montero,
GTO, Sunbeam Alpine, VW Dasher
Post by cn90 »
holler1,
You are correct, the only way to replace the rectangular seal is via the wheel well. Even so, I stripped the rear T40 bolt!!! Read on...
1. Jack up RF area, remove wheel, fold back liner with vise-grip to expose the crank pulley, place jackstands under subframe etc.
- Now you can see the oil leak blown around during driving...
- For the records, P.O. replaced the oil cooler lines x2 and the O-rings, but didn't replace the rectangular seal. So the oil leak was at the rectangular seal area.
2. The FRONT T40 came out nice and easy with this combo:
* L-shaped T40 key + socket + iron pipe.
3. The REAR T40: I stripped it, even with tons of caution (going slow, making sure the T40 key fit properly in the hole etc. etc.). It took close to 1.5h to drill out the bolt head! Finally I realized I had a masonry drill bit, which made the drilling job easier. The bolt head came out. Then I used vise-grips to remove the broken stud.
The dealer was closed, so I used an old Tstat housing bolt (it was longer so I used some nuts/washers to achieve correct height) as a temp fix until I get the correct bolt.
The bottom line: get new bolts before starting this job!
4. For the 10-mm bolt holding the cooler lines bracket (near the AC compressor). The only combo that worked:
* 1/4-inch 10-mm socket + 1/4-inch swivel + 1/4-inch extension/ratchet.
5. For the rectangular seal: I applied a thin smear of wheel-bearing grease to help hold it in place during installation. It worked great. Since you are doing this "blind", use the your finger to sweep around to be sure the seal sits properly in the proper groove.
Post by cn90 »
Can some gurus help re PN? I need PN for:
1. The two (2) T40 bolts that hold the oil tstat housing to the engine.
2. The single Torx bolt that holds the 2 cooler lines to the tstat housing.
Thanks!
confused_al
Year and Model: 1996 TLA wagon
Post by confused_al »
I replaced that seal about a year (1500 miles) ago and it stated leaking again after summer. It could be just my lousy technique, but this time I am going to put some RTV around it.
BTW, nice pics!
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
Post by cn90 »
I came across a Volvo website (Volvo of Lisle parts website) and saw these PNs:
* The two (2) Torx bolts: 986226. But when checking 986226, it seems this bolt is longer that what I have in my 1998 S70 GLT.
* The single bolt 986212, seems correct.
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
Related comment:
I had an oil cooler thermostat leaking after my install, replacing the square o-ring didn't fix it, I finally figured out that the soft aluminum housing was bent, probably from me overtightening it. So I straightened it out now all is well.
