How to refurbish a turbo
This topic is in the MVS Volvo Repair Database » How to Refurbish a Volvo Turbo
tailor
Year and Model: 2004 XC90 2.5T AWD
Been thanked: 2 times
Post by tailor »
I am in no way trying to plagiarize this incredible write up ...but i will take the credit for posting it. :mrgreen:
I hope that we can enter it into the database!
http://www.volvoforums.org.uk/showthread.php?t=48611
1994 850 Auto Turbo wagon 306000km (Sold)
2004 XC90 AWD 188000km
"Life is like a reel to reel tape recorder,
the closer you get to the end,
the faster it spins."
Abe Gottschalk
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Thanks Tailor, I'm pinning this in the repair database.
I also have a write-up in pdf format from the Kansai guy who sells on eBay but his stuff is copyrighted and so I cannot post it here. A couple of things to add-
1. The circlip is a real bitch- make sure you have a very good set of the correct pliers. A cheap pr. will bend and break.
2. Get the stuff as clean as you can... the photo's still show a bunch of grime after the rebuild- you want to use the green scouring pad and really get the gunk off.
3. The turbine fins are very sharp and will cut you if you try to grab them- use a towel but be careful you don't bend them- they also will bend easily. The part that they bend easiest is when hammering w/ a rubber mallet to get the casing off (don't slip!).
Good luck with those who try to do a turbo rebuild!
