Where are adjustment points for front alignment
This topic is in the MVS Volvo Repair Database » Alignment on Volvo 850 -- Specifications & Procedures
C@lvin
Been thanked: 2 times
Post by C@lvin »
I just removed and reinstalled one of the front struts and am planning to get an alignment per commonly heard recommendations. But it made me wonder why since the only bolts or screws that I removed and replaced do not have any ability to be adjusted that I can tell. Therefore, I don't understand how having done that could get it out of alignment. :?:
Does anyone know where the alignment adjustments are made in the front end and or why it must be aligned after removing a strut? :?
Thanks,
Calvin
98 S70
00 V70
240,245,760,940,850 Turbo
charlyW
Year and Model: 97 855 T-5 CD
Post by charlyW »
C@lvin wrote:I just removed and reinstalled one of the front struts and am planning to get an alignment per commonly heard recommendations. But it made me wonder why since the only bolts or screws that I removed and replaced do not have any ability to be adjusted that I can tell. Therefore, I don't understand how having done that could get it out of alignment. :?:
Thanks,
Here are the instruction on how the adjustments are done. Toe in Toe out is the easiest adjustment thats done on the track rod end [Tie rod end I think in the USA]
FrontSuspension.pdf
(113.24 KiB) Downloaded 6887 times
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
C@lvin
Post by C@lvin »
Thanks CharlyW. the PDF is really good but unless I missed something it includes all the front suspension removal and installation yet doesn't say anything about alignment
That still leaves me with my original quesion as to why an alignment is necessary after removing and replacing the strut assembly since the only bolts or nuts that were involved (three at the top of the tower, one for the sway bar end link, and the two strut to knuckle bolts) cannot be adjusted. So what opportunity was there for the alignment to become out of alignment?
Thanks,
Calvin
98 S70
00 V70
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
As you put things back the only adjustment you have is toe in. You can be off quite a bit on camber after a strut change though and in order to correct you will need to buy camber kits which are essentially eccentric mounting bolts.
C@lvin
Post by C@lvin »
Thanks Lee. But why? What did I do that provided the opportunity to become misaligned? Am I wrong that the bolts and nuts that I removed and replaced have no adjustment ability to them? Where are the camber and toe adjustments made in the suspension? Sorry for being dense, but I just don't get it.
Thnaks again,
Calvin
98 S70
00 V70
charlyW
Post by charlyW »
Sorry about that included the wrong PDF try these, as Ozark Lee says theres not much you can adjust.
wheel alignment specifications and procedures.pdf
(81.15 KiB) Downloaded 4703 times
wheel alignment theory operation.pdf
(130.51 KiB) Downloaded 2061 times
C@lvin
Post by C@lvin »
Thanks CharlyW.
So.....if I understand correctly, since I didn't change or adjust the steering end links I would not have changed or affected to toe-in.
But......after reading about camber adjustment I still don't understand how the camber can change since there is no adjustment to any of the bolts/nuts that affect it. Why should it ever get out of adjustment in the first place so that it requires introducing the eccentric mounting bolts in order to crate an adjustable mounting?
I guess it's all sort of a moot point at the moment since the alignment shop just called to tell my I can pick up my car, but I still want to understand for future situations and hope that I didn't waste the $$ this morning.
Calvin
98 S70
00 V70
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Why should it ever get out of adjustment in the first place so that it requires introducing the eccentric mounting bolts in order to create an adjustable mounting?
POTHOLES!
After so many bumps, the suspension components get slightly bent (not so much visibly, but it does happen) that they knock off the original manufactured specificiations for camber. The quick & easy fix is simply installing these bolts.
http://www.dirtyimpreza.com/forums/show ... php?t=6365
'98 S70 T5
2016 Chevy Cruze Premier
C@lvin
Post by C@lvin »
OK I can accept that after years of abuse the suspension can work it's way out of spec.
That was a very good link. Thanks.
Calvin
98 S70
00 V70
Post by Ozark Lee »
In theory you are spot on correct C@lvin. My reality though is that everytime I change anything on the front end (short of end links) the alignment is off and I can feel it in the steering wheel.
