HD Radio install
This topic is in the MVS Volvo Repair Database » HD Radio install
mrreilly
Year and Model: 1998 Volvo S70 GLT
Volvo Repair Database HD Radio install
Post by mrreilly »
This past week I received a free HD Radio kit. I just installed it today and got everything hooked up properly. Everything plugs in where it should and it turns on just fine. The only problem is that when I turn the unit on it doesn't do anything. If I have the unit off and my radio is on, my radio will play music fine. When I switch the unit on everything goes fuzzy. Does anyone know anything about these thing s or anything that could help my getting it working??
Here's the unit: http://www.crutchfield.com/p_60744000/Directed-Car-Connect.html?tp=134&tab=essential_info
1998 Volvo S70 GLT Black/Tan
Approx. 173,000 3/27/2010
My major repairs:
Timing Belt, Left&Right Control Arms, Tie-rod ends, Lower Engine Mount, Engine Stabilizer Mount, IPD Sway Bar Links, Brakes , Head Gasket, PCV System, Turbo Rebuild, and more
RSM-GA
Year and Model: C70 T5 Coupe 2002
Post by RSM-GA »
contact Crutchfield's tech support. They should be able to help you. It sounds like the connections are reversed though.
[img]C:\Users\sony\Pictures\2010-01-17[/img]
My garage:
2002 Volvo C70 T5 Coupe
1998 Volvo S70 T5 91k sold
1999 Volvo S70 190k scraped
1999 Mercedes Benz E320 199k sold
2000 Volvo V70 SE sold
1999 Taurus SHO V8 sold
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
There could be a good news/bad news aspect to your HD add on,
but first, we're gonna need some details.
First off, didja go RCA or antenna connection to the stock radio?
Which stock radio? Model number?
Do you have an amp?
mrreilly
Post by mrreilly »
actually i ended up randomly figuring it out lol I set the hd radio unit and my radio to the same station and it synced up. Everything is good now!
My major repairs:
BEJinFbk
Post by BEJinFbk »
So, it sounds like you're using the FM modulator option to feed the HD to your existing radio.
The bummer is...It ain't HD. It'll never sound any better than the FM that came with the car.
BUT - If you've got an amp... :mrgreen: Possibilities, my friend! Great possibilities! :wink:
cbessant
Year and Model: 1998 V70 T5
Post by cbessant »
I have a 1998 V70 T5 with the OEM AM/FM/CD/Cassette radio. I want to add HD radio to improve Am fidelity. I tried to replace the OEM unit with a Kenwood KDC-HD545U unit at a good car audio shop. The AM reception was horrific, much worse/less reception than the OEM unit. HD Digital rarely kicked in. The shop was concerned about Volvo's diversity antennae that might prevent the AM signal from working properly as the OEM unit is tuned to the V70's antennae. We tried using a power antennae to replace/bypass the V70's antennae, and no good.
I had the OEM unit put back in.
Can anyone suggest how I can do this?
Thank you.
Chuck
BEJinFbk
Post by BEJinFbk »
Did they know that V70's have built in antenna amplifiers?
They 'll need to connect that Blue wire marked Power Antenna from the wiring adapter
to the Blue/White " P.(ower) Cont.(ontrol) " output from your new KDC-HD545U .
( Usually, one would match Blue to Blue, but your KDC-HD545U owners manual says use the Blue/White.)
Otherwise, the Volvo's antenna amp won't power up. No Antenna Amp? No Signal from the antenna...
cbessant
Post by cbessant »
Thank you for the advice. I'll ask them.
Chuck
