While I had the engine out, I decided now would be the best time to inspect/repair the PCV system as well. I did find the plastic hose from the oil trap to the intake hose to be broken, but the hose was pretty clean inside, as well as all the ports on the engine. Since I had intended on replacing the the oil trap anyways, I cut it open just to see what was inside.
I was quite surprised to find it was just a hollow box. Is this how it's supposed to be? I was expecting to find some kind of collection medium inside, like steel wool, or some kind of batting, considering how these things are supposedly clogged up so often. To be honest, I don't see how these things could possibly get clogged up inside, unless the engine was pushing massive amounts of oil through the PCV system, and then I'd bet that the engine had some kind of major internal wear that cleaning/replacing the PCV system wouldn't help.
My trap didn't appear as if someone had been inside it before - the seal looked like a factory plastic weld, not a glue or epoxy that was added later.
850 oil trap - just a hollow box?
Schmitty
- Year and Model: 1995 Volvo 850 turbo
I'm not 100%, but that sounds normal. I seem to recall reading about someone being surprised the oil trap was hollow. Although I've been reading bits and pieces of every topic I can get my finger tips on, so my statement right now is not reliable (I could be thinking of something else).
1995 850 Turbo -- 118K miles
91 Octane Premium + 3oz. Lucas Oil
Synthetic Mobil1 5W30
K&N Air Filter
K&N Air Filter
- Year and Model: Many Volvos
- Been thanked: 76 times
A hollow box with baffles is correct. The oil comes in and the oil goes out but it allows the vapors to be bled off. It does no other filtering (thank God) or it would clog up even sooner.
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Usually it's not the box itself that gets clogged, but instead it's all the hoses, particularly at connection points. The PTC nipple has a smaller diameter and gets clogged easily.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
VolvoTurbo850
- Year and Model: 1994 850 (T5)
It is an emission control system to prevent oil vapours (result of the oil when it heats up and the mechanical movement of valves) from escaping into the environment. If you note the pipe to that box is connected to the top of the valve main cover.
The vapour goes into the pipe and condenses, as it does this it becomes a liquid again flows down to the box. From there it flows back into the lower part of the engine to combine with the rest of the oil reserve. The box is just like a transition zone and funnel for the oil.
Quite often there is a real build up of resin on the channel where the box connects to the engine block. This in turn clogs the system and can add more pressure on the PVC system too.
Such a basic concept but I really think Volvo designed this as an afterthought because it is such a pain to get to!
The Fleet
2001 V70 (NA) 2.5
1999 C70 Conv. Turbo 2.3 HPT
1998 S70 Turbo (T5) SE
1994 850 Turbo (T5)
1980 Corvette (Corvolvo)
Previous Possessions: (4) 240's, (1) 740, (9) 850's, (5) 70 Series
Projects on the go: NONE... Yet!
MatDesign84
- Year and Model: 1997,855 T5
I see it everywhere on the forums but never asked. What is a PTC?
Currently: 1997, 855 T5 | 1998 Subaru Legacy GT 2.5
Previous: 1997, 850 GLT | 1993, 850 GLT | 1988, BMW 325i, 1990 Volvo 240 DL
"That's good to know though in case they let loose again, but I swear if they do, I'll punch something." -jblackburn
It is the Positive Temperature Coefficient valve. Calling it a valve is a bit of a misnomer since it is really just a tube with a heater around it. It doesn't vary the airflow at all (until it clogs up), it just heats the PCV gases up before they get shipped off to the intake system to be re-burned. It is located on the snorkel tube just before the turbo and it has a PCV line plugged into it as well as an electrical connector.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Here's the little thing in question:
'98 S70 T5
2016 Chevy Cruze Premier
MatDesign84
Oh alright.
